Speaker Glue
I had a couple of speakers with tiny moth holes in them that was causing a vibration problem at mid volume because the cone was thin in those spots. I used some liquid tape to cover the holes and found it worked great... and solved the vibration problem.
Speaker Glue - by w4rtc - 04-04-2013, 10:21 PM
RE: Speaker Glue - by Arran - 04-04-2013, 10:27 PM
RE: Speaker Glue - by klondike98 - 04-04-2013, 10:31 PM
RE: Speaker Glue - by NostalgiaRadioTime - 04-04-2013, 10:44 PM
RE: Speaker Glue - by Bob Andersen - 04-04-2013, 11:17 PM
RE: Speaker Glue - by Arran - 04-04-2013, 11:47 PM
RE: Speaker Glue - by klondike98 - 04-05-2013, 09:33 AM
RE: Speaker Glue - by Chuck Schwark - 04-05-2013, 09:35 AM
RE: Speaker Glue - by Eric Adams - 04-05-2013, 10:41 AM
RE: Speaker Glue - by w4rtc - 04-05-2013, 11:00 AM
RE: Speaker Glue - by Mondial - 04-05-2013, 11:06 AM
RE: Speaker Glue - by Chuck Schwark - 04-05-2013, 01:50 PM
Philco 91 Tuning Condenser
There are currently 6681 online users. [Complete List]
» 1 Member(s) | 6680 Guest(s)
