What my 16B looked like when I got it and then....
"Hang on, help is on the way - as in new repro 1935-37 Philco chevron or "V" cloth. I do not know when it will be available, but it is being developed."
This is good news. I've got a 116B thats been sitting here all ready to go except for lack of replacement grille cloth.
Steve Chambers
RE: What my 16B looked like when I got it and then.... - by Steve Chambers - 04-05-2013, 12:52 PM
