Name the bands
The various meter bands are used at different times of the day. 49m (6 MHz) is mostly a nighttime band. 31m (9 MHz) is a night and day band. 25m (12 MHz) is a daytime band. 19m (15MHz) is a late afternoon band. The major broadcasters move among these bands, sometimes broadcasting on more than one at a time because of differences in the coverage of the different bands during different times of day.
Name the bands - by NostalgiaRadioTime - 04-05-2013, 05:47 PM
RE: Name the bands - by morzh - 04-05-2013, 08:00 PM
RE: Name the bands - by NostalgiaRadioTime - 04-05-2013, 08:11 PM
RE: Name the bands - by Arran - 04-05-2013, 09:09 PM
RE: Name the bands - by BrendaAnnD - 04-05-2013, 10:09 PM
RE: Name the bands - by morzh - 04-06-2013, 11:00 AM
RE: Name the bands - by GarySP - 04-06-2013, 03:47 PM
RE: Name the bands - by morzh - 04-06-2013, 05:37 PM
RE: Name the bands - by Paul Philco322 - 04-06-2013, 08:56 PM
RE: Name the bands - by morzh - 04-06-2013, 10:59 PM
RE: Name the bands - by Michael Dennis - 04-07-2013, 12:25 AM
There are currently 6148 online users. [Complete List]
» 1 Member(s) | 6147 Guest(s)
