46-200 code 122
You have a Code 122 version. Have not seen the Riders, but it sounds like it's not correct. R100 (as called out in the Philco service Bulletin PR-1135 for Code 121 and Bulletin PR-1298 for the 122) is an 80 ohm candohm unit (filament string ballast). The 46-200 Code 121 did NOT have a 14B6 in it.
The Model 48-200 has that tube lineup in the Rider's you are referring to. There also is no R100 filament string ballast resistor in the 48-200 because the IF tube has a 14 volt filament (14A7) instead of the 6.3 volt (7B7), the difference which R100 makes up.
Riders got it mixed up. There's the confusion.
46-200 code 122 - by Jim Dutridge - 11-28-2007, 05:30 PM
[No subject] - by Chuck Schwark - 11-28-2007, 06:20 PM
[No subject] - by Jim Dutridge - 11-28-2007, 07:26 PM
[No subject] - by Chuck Schwark - 11-28-2007, 07:39 PM
[No subject] - by Jim Dutridge - 11-28-2007, 07:56 PM
[No subject] - by Chuck Schwark - 11-28-2007, 11:12 PM
[No subject] - by Jim Dutridge - 11-29-2007, 05:43 PM
[No subject] - by Chuck Schwark - 11-29-2007, 07:51 PM
[No subject] - by Jim Dutridge - 11-30-2007, 02:52 PM
[No subject] - by Jim Dutridge - 12-01-2007, 12:25 PM
[No subject] - by Jim Dutridge - 12-06-2007, 04:36 PM
There are currently 9773 online users. [Complete List]
» 1 Member(s) | 9772 Guest(s)
