Philco 42-1008
Hi everyone. The club im in has been donated a 42-1008. So today we took it apart. First thing that we found is that someone needed the tuning shaft more than we did. SO is there a site to go that might have several junk chassis we might find that tuning shaft or a least get a picture of what it looks like.
Also going to need the rubber wheels for the "beam of light player" need a source for that.
Thanks for any help. John
Philco 42-1008 - by 37FORDSEAT - 04-06-2013, 04:25 PM
RE: Philco 42-1008 - by ipwizard - 04-08-2013, 02:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7132 online users. [Complete List]
» 1 Member(s) | 7131 Guest(s)
