Pilot T601 FM Tuner
Because this is a variable cap there is no specific value. Nostalgia Air has a schematic but it doesn't have a parts list. There must be some capacitance range specified for these trimmers. I poked around in my literature, but nothing gave a range. Is this trimmer mounted on the tuning condenser?
John Honeycutt
Pilot T601 FM Tuner - by Micro9 - 04-06-2013, 12:25 PM
RE: Pilot T601 FM Tuner - by Raleigh - 04-06-2013, 06:10 PM
RE: Pilot T601 FM Tuner - by Micro9 - 04-06-2013, 06:43 PM
RE: Pilot T601 FM Tuner - by Raleigh - 04-07-2013, 11:39 AM
RE: Pilot T601 FM Tuner - by codefox1 - 04-07-2013, 12:22 PM
RE: Pilot T601 FM Tuner - by Micro9 - 04-07-2013, 06:21 PM
RE: Pilot T601 FM Tuner - by BrendaAnnD - 04-07-2013, 07:30 PM
RE: Pilot T601 FM Tuner - by BrendaAnnD - 04-07-2013, 07:38 PM
RE: Pilot T601 FM Tuner - by Ron Ramirez - 04-07-2013, 09:08 PM
RE: Pilot T601 FM Tuner - by BrendaAnnD - 04-07-2013, 10:51 PM
RE: Pilot T601 FM Tuner - by Micro9 - 04-10-2013, 11:00 PM
There are currently 9936 online users. [Complete List]
» 3 Member(s) | 9933 Guest(s)
