Quick consult needed from experts:eBay item Philco 38-12
Here's the question:
http://www.ebay.com/itm/330901052815?ssP...1423.l2649
This is the Philco 12. However the chassis is from Transitone.
What I am trying to figure out is if the speaker is Transitone or 38-12.
As you know I am trying to replace my 38-15 speaker.
You can see the output transformer says 14A4.
The numbers on the rear of the speaker are obscured but the seller tried to see what they are and wrote that (although she is not sure 100%) they may be
1614 and 1728.
I am not sure that 1) the speaker is 38-12 one, 2) it is a field coil type and not perm magnet one.
I need to figure it out before next 7 hours or so, so I know whether to buy this for parts or not.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
