Philco 60 MB scored
Luckily, it all came back together quite nicely as you can seen in the cabinet restoration forum Icon_biggrin
http://www.philcoradio.com/phorum/showth...0#pid40300
Philco 60 MB scored - by Bob Andersen - 04-05-2013, 10:42 PM
RE: Philco 60 MB scored - by kporter - 04-05-2013, 11:55 PM
RE: Philco 60 MB scored - by TA Forbes - 04-06-2013, 01:19 AM
RE: Philco 60 MB scored - by klondike98 - 04-06-2013, 09:12 AM
RE: Philco 60 MB scored - by Art Hoch - 04-06-2013, 10:13 PM
RE: Philco 60 MB scored - by Bob Andersen - 04-07-2013, 02:44 PM
There are currently 10171 online users. [Complete List]
» 3 Member(s) | 10168 Guest(s)
