Philco 60MB cabinet restoration
Bob,
I realistically only had to clean and rewax this case. The only touchup I did was on the black trim. If my memory serves me I simply used black laquer.
Good luck with yours. Please post some photos of completed cabinet.
Joe
Philco 60MB cabinet restoration - by Bob Andersen - 04-06-2013, 06:57 PM
RE: Philco 60MB cabinet restoration - by jph14 - 04-07-2013, 07:46 AM
RE: Philco 60MB cabinet restoration - by jph14 - 04-07-2013, 04:26 PM
RE: Philco 60MB cabinet restoration - by Art Hoch - 04-07-2013, 05:40 PM
RE: Philco 60MB cabinet restoration - by Geoff - 04-08-2013, 11:57 PM
RE: Philco 60MB cabinet restoration - by Arran - 04-09-2013, 10:38 PM
RE: Philco 60MB cabinet restoration - by Arran - 04-21-2013, 11:55 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-04-2013, 12:48 AM
RE: Philco 60MB cabinet restoration - by Arran - 05-09-2013, 06:45 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-17-2013, 08:20 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-18-2013, 08:55 PM
RE: Philco 60MB cabinet restoration - by Arran - 05-20-2013, 11:54 PM
RE: Philco 60MB cabinet restoration - by jph14 - 05-22-2013, 04:46 PM
RE: Philco 60MB cabinet restoration - by EricS - 08-24-2013, 09:22 PM
There are currently 10319 online users. [Complete List]
» 2 Member(s) | 10317 Guest(s)
