38-15 Restoration
One more thing I don't understand about some of the Philcos. It seems every once in a while I see radios where the wires carrying quite a high voltage, like those going to a voice coil (full B+ and rect. output, no resistors in between) go though a hole in the chassis without any grommet or anything to protect them from the cutting edge of that hole. If it ever rubs through, this will be the end of the rectifier section.
38-15 Restoration - by morzh - 02-02-2013, 05:59 PM
RE: 38-15 Repair - by Ron Ramirez - 02-02-2013, 10:11 PM
RE: 38-15 Repair - by morzh - 02-02-2013, 10:22 PM
RE: 38-15 Repair - by morzh - 02-02-2013, 10:32 PM
RE: 38-15 Repair - by Paul Philco322 - 02-02-2013, 11:21 PM
RE: 38-15 Repair - by morzh - 02-02-2013, 11:25 PM
RE: 38-15 Repair - by Ron Ramirez - 02-02-2013, 11:49 PM
RE: 38-15 Repair - by morzh - 02-02-2013, 11:54 PM
RE: 38-15 Repair - by Arran - 02-03-2013, 09:31 PM
RE: 38-15 Repair - by morzh - 02-03-2013, 10:17 PM
RE: 38-15 Repair - by morzh - 02-09-2013, 02:28 PM
RE: 38-15 Repair - by morzh - 04-06-2013, 04:54 PM
RE: 38-15 Repair - by codefox1 - 04-07-2013, 10:33 AM
RE: 38-15 Repair - by morzh - 04-07-2013, 10:50 AM
RE: 38-15 Repair - by morzh - 04-07-2013, 04:58 PM
RE: 38-15 Repair - by morzh - 04-07-2013, 05:04 PM
RE: 38-15 Repair - by morzh - 04-07-2013, 06:27 PM
RE: 38-15 Repair - by morzh - 04-07-2013, 07:49 PM
RE: 38-15 Restoration - by Ron Ramirez - 04-09-2013, 08:13 PM
RE: 38-15 Restoration - by morzh - 04-09-2013, 08:36 PM
RE: 38-15 Restoration - by morzh - 04-09-2013, 08:59 PM
RE: 38-15 Restoration - by morzh - 04-10-2013, 10:24 PM
RE: 38-15 Restoration - by Ron Ramirez - 04-11-2013, 05:32 AM
RE: 38-15 Restoration - by morzh - 04-11-2013, 11:16 AM
RE: 38-15 Restoration - by morzh - 04-20-2013, 09:08 PM
RE: 38-15 Restoration - by Arran - 04-20-2013, 09:30 PM
RE: 38-15 Restoration - by morzh - 04-20-2013, 09:41 PM
RE: 38-15 Restoration - by morzh - 04-21-2013, 06:22 PM
RE: 38-15 Restoration - by morzh - 04-22-2013, 05:24 PM
RE: 38-15 Restoration - by morzh - 04-24-2013, 11:27 PM
RE: 38-15 Restoration - by Ron Ramirez - 04-25-2013, 09:21 AM
RE: 38-15 Restoration - by 7estatdef - 04-25-2013, 12:02 PM
RE: 38-15 Restoration - by morzh - 04-26-2013, 12:41 AM
RE: 38-15 Restoration - by BrendaAnnD - 04-26-2013, 02:32 AM
RE: 38-15 Restoration - by morzh - 04-26-2013, 11:46 AM
RE: 38-15 Restoration - by Ron Ramirez - 04-26-2013, 11:48 AM
RE: 38-15 Restoration - by morzh - 04-26-2013, 11:54 AM
RE: 38-15 Restoration - by morzh - 04-26-2013, 11:56 AM
RE: 38-15 Restoration - by morzh - 04-26-2013, 06:20 PM
RE: 38-15 Restoration - by morzh - 04-27-2013, 10:57 AM
RE: 38-15 Restoration - by morzh - 05-01-2013, 09:21 PM
RE: 38-15 Restoration - by Mondial - 05-01-2013, 10:06 PM
RE: 38-15 Restoration - by morzh - 05-01-2013, 10:21 PM
RE: 38-15 Restoration - by morzh - 05-02-2013, 06:16 PM
RE: 38-15 Restoration - by morzh - 05-03-2013, 11:48 PM
RE: 38-15 Restoration - by BrendaAnnD - 05-04-2013, 01:12 AM
RE: 38-15 Restoration - by morzh - 05-04-2013, 12:37 PM
RE: 38-15 Restoration - by morzh - 05-07-2013, 10:59 PM
RE: 38-15 Restoration - by morzh - 05-12-2013, 09:51 PM
RE: 38-15 Restoration - by Arran - 05-12-2013, 11:03 PM
RE: 38-15 Restoration - by morzh - 05-12-2013, 11:16 PM
RE: 38-15 Restoration - by Arran - 05-13-2013, 12:18 AM
RE: 38-15 Restoration - by morzh - 05-13-2013, 09:13 AM
RE: 38-15 Restoration - by morzh - 05-13-2013, 09:17 PM
RE: 38-15 Restoration - by morzh - 05-14-2013, 11:06 PM
RE: 38-15 Restoration - by morzh - 05-15-2013, 10:45 PM
RE: 38-15 Restoration - by morzh - 05-15-2013, 10:50 PM
RE: 38-15 Restoration - by morzh - 05-17-2013, 11:55 AM
RE: 38-15 Restoration - by Mondial - 05-17-2013, 02:59 PM
RE: 38-15 Restoration - by morzh - 05-17-2013, 04:25 PM
RE: 38-15 Restoration - by morzh - 05-17-2013, 10:54 PM
RE: A 38-15 - by Paul Philco322 - 02-02-2013, 06:10 PM
RE: A 38-15 - by morzh - 02-02-2013, 09:09 PM
RE: A 38-15 - by morzh - 02-02-2013, 09:39 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
