Photos of the Philco 96! (before)
Here are some photos! I am excited to start! I am happy to find that the speaker "unplugs" and isnt hardwired to the chassis. Other than tube changes, it doesnt look like anyones obviously worked on this guy!
http://imgur.com/a/1qI5m
I uploaded some images into an imgur album.
Photos of the Philco 96! (before) - by mazzybear - 04-07-2013, 07:53 PM
RE: Photos of the Philco 96! (before) - by Arran - 04-08-2013, 02:37 AM
Philco 91 Tuning Condenser
There are currently 3832 online users. [Complete List]
» 1 Member(s) | 3831 Guest(s)
