Photos of the Philco 96! (before)
Well. that is why I wanted you to know. For some people it would not matter. If I am going to put time and money into a radio, I want it to look original (factory) when I get done. Hard to do when the legs are cut down.
Photos of the Philco 96! (before) - by mazzybear - 04-07-2013, 07:53 PM
RE: Photos of the Philco 96! (before) - by Phlogiston - 04-08-2013, 01:06 AM
RE: Photos of the Philco 96! (before) - by Arran - 04-08-2013, 02:37 AM
Philco 91 Tuning Condenser
