Philco 42-1008
John,
Ebay, or Play Things of the Past http://www.oldradioparts.com/.
Post in the want ads on this site might also lead you to something.
-Keith
Philco 42-1008 - by 37FORDSEAT - 04-06-2013, 04:25 PM
RE: Philco 42-1008 - by ipwizard - 04-08-2013, 02:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7048 online users. [Complete List]
» 1 Member(s) | 7047 Guest(s)
