Photos of the Philco 96! (before)
There is a fellow named Chuck in NJ who can make an excellent reproduction of that 96 shield. If interested, let me know and I'll provide his email address.
Photos of the Philco 96! (before) - by mazzybear - 04-07-2013, 07:53 PM
RE: Photos of the Philco 96! (before) - by Arran - 04-08-2013, 02:37 AM
RE: Photos of the Philco 96! (before) - by Ron Ramirez - 04-08-2013, 04:26 PM
Philco 91 Tuning Condenser
There are currently 3910 online users. [Complete List]
» 1 Member(s) | 3909 Guest(s)
