116x Restoration
Finished the recapping last night. Powered up and it sings. The tone switch has something funky going on with it though. When moving the tone switch the sound will squeal, and pop and carry on until you get it just right. I sprayed it and the band switch with deoxit and let it sit over night we'll see if that made a difference tonight.
I have to say from the few minutes I had the set playing that it is a very sensitive set. I suspect it will be a very good performer after an alignment.
-Keith
116x Restoration - by ipwizard - 04-04-2013, 01:53 AM
RE: 116x Restoration - by morzh - 04-04-2013, 11:43 AM
RE: 116x Restoration - by ipwizard - 04-05-2013, 12:21 AM
RE: 116x Restoration - by morzh - 04-05-2013, 03:11 PM
RE: 116x Restoration - by 7estatdef - 04-05-2013, 03:55 PM
RE: 116x Restoration - by ipwizard - 04-05-2013, 05:30 PM
RE: 116x Restoration - by Ron Ramirez - 04-05-2013, 09:18 PM
RE: 116x Restoration - by 7estatdef - 04-05-2013, 11:08 PM
RE: 116x Restoration - by codefox1 - 04-06-2013, 08:24 AM
RE: 116x Restoration - by ipwizard - 04-06-2013, 12:58 PM
RE: 116x Restoration - by ipwizard - 04-09-2013, 11:44 AM
RE: 116x Restoration - by ipwizard - 04-15-2013, 05:25 PM
RE: 116x Restoration - by Mondial - 04-15-2013, 09:04 PM
RE: 116x Restoration - by 7estatdef - 04-15-2013, 09:40 PM
RE: 116x Restoration - by ipwizard - 04-16-2013, 02:37 AM
RE: 116x Restoration - by ipwizard - 05-14-2013, 12:48 AM
RE: 116x Restoration - by BrendaAnnD - 05-14-2013, 01:10 AM
RE: 116x Restoration - by 7estatdef - 05-14-2013, 06:51 AM
RE: 116x Restoration - by Chuck Schwark - 05-14-2013, 09:05 AM
RE: 116x Restoration - by ipwizard - 05-14-2013, 11:16 AM
RE: 116x Restoration - by Chuck Schwark - 05-14-2013, 01:03 PM
RE: 116x Restoration - by BrendaAnnD - 05-14-2013, 03:49 PM
RE: 116x Restoration - by Chuck Schwark - 05-14-2013, 09:05 PM
RE: 116x Restoration - by Mondial - 05-14-2013, 10:26 PM
RE: 116x Restoration - by ipwizard - 05-15-2013, 06:25 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6969 online users. [Complete List]
» 1 Member(s) | 6968 Guest(s)
