Suggestions, please (Majestic Model 20)
Good chance you have a carbon trace on one or both sockets if everything else checks out OK. Happens quite a bit on the old sets, and difficult to find. Replace 'em before you fire up the set again. If the 45's are good, would be a shame to lose them.
I'm sure someone has some to contribute or barter, try the classiied section, need to know existing dimensions too.
RE: Suggestions, please (Majestic Model 20) - by codefox1 - 04-10-2013, 10:21 AM
There are currently 7026 online users. [Complete List]
» 1 Member(s) | 7025 Guest(s)
