  • 1 Vote(s) - 5 Average
Repurpose a Philco
Art,
Certainly it was not my intention to freely do something that you guys would despise.
The money is not the issue, we like looking at the philco, and despise all the flashing lights that are associated with todays technology, and we have no intention of giving up either.
We were just trying to figure out if a tasteful way exists to merge the two.
and it is clear at least in this world (which I kind of expected) that is not possible.
Which is cool with me.
Repurpose a Philco - by mis4tun81 - 04-09-2013, 12:31 PM
RE: Repurpose a Philco - by jerryhawthorne - 04-09-2013, 05:55 PM
RE: Repurpose a Philco - by w4rtc - 04-09-2013, 06:10 PM
RE: Repurpose a Philco - by Doug Houston - 04-09-2013, 07:24 PM
RE: Repurpose a Philco - by Arran - 04-09-2013, 07:31 PM
RE: Repurpose a Philco - by shaler78 - 04-09-2013, 08:39 PM
RE: Repurpose a Philco - by shaler78 - 04-09-2013, 09:09 PM
RE: Repurpose a Philco - by chris25260880 - 04-10-2013, 12:40 AM
RE: Repurpose a Philco - by codefox1 - 04-10-2013, 10:27 AM
RE: Repurpose a Philco - by PhilcoMike - 04-10-2013, 11:23 AM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 11:40 AM
RE: Repurpose a Philco - by Art Hoch - 04-10-2013, 12:09 PM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 12:19 PM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 12:21 PM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 12:26 PM
RE: Repurpose a Philco - by Ron Ramirez - 04-10-2013, 01:38 PM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 03:55 PM
RE: Repurpose a Philco - by Gene Pederson - 04-10-2013, 04:15 PM
RE: Repurpose a Philco - by shaler78 - 04-10-2013, 04:41 PM
RE: Repurpose a Philco - by Phlogiston - 04-10-2013, 07:49 PM
RE: Repurpose a Philco - by TimC - 04-10-2013, 09:10 PM
RE: Repurpose a Philco - by Arran - 04-10-2013, 09:38 PM
RE: Repurpose a Philco - by GarySP - 04-10-2013, 10:03 PM
RE: Repurpose a Philco - by Arran - 04-10-2013, 10:59 PM
RE: Repurpose a Philco - by gary rabbitt - 04-11-2013, 03:56 PM
RE: Repurpose a Philco - by DeckApe - 04-13-2013, 10:55 AM
Philco 91 Tuning Condenser
There are currently 6410 online users. [Complete List]
» 1 Member(s) | 6409 Guest(s)
