  • 1 Vote(s) - 5 Average
Repurpose a Philco
I found out through looking through the gallery that your set is a 625S, as opposed to a 625J which is also a console, or a 625B which is a tombstone style table set. The 625S was the least expensive of the two consoles at $59.95 as opposed to $69.95 for the 625J, it may also be somewhat rarer. The 625 debut in January 1936 as a revised version of a Philco 620, the main difference between the 620 and the 625 is that the 625 has a shadow mask that moves up or down behind the dial to illuminate what ever band is selected. Also your example, though it is in need of a refinish, is much more original then the set featured in the gallery. I have a 620B and I am here to tell you that it is a hot performer, a very sensitive and selective set that will run circles around the majority of new AM radios.
Repurpose a Philco - by mis4tun81 - 04-09-2013, 12:31 PM
RE: Repurpose a Philco - by jerryhawthorne - 04-09-2013, 05:55 PM
RE: Repurpose a Philco - by w4rtc - 04-09-2013, 06:10 PM
RE: Repurpose a Philco - by Doug Houston - 04-09-2013, 07:24 PM
RE: Repurpose a Philco - by Arran - 04-09-2013, 07:31 PM
RE: Repurpose a Philco - by shaler78 - 04-09-2013, 08:39 PM
RE: Repurpose a Philco - by shaler78 - 04-09-2013, 09:09 PM
RE: Repurpose a Philco - by chris25260880 - 04-10-2013, 12:40 AM
RE: Repurpose a Philco - by codefox1 - 04-10-2013, 10:27 AM
RE: Repurpose a Philco - by PhilcoMike - 04-10-2013, 11:23 AM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 11:40 AM
RE: Repurpose a Philco - by Art Hoch - 04-10-2013, 12:09 PM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 12:19 PM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 12:21 PM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 12:26 PM
RE: Repurpose a Philco - by Ron Ramirez - 04-10-2013, 01:38 PM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 03:55 PM
RE: Repurpose a Philco - by Gene Pederson - 04-10-2013, 04:15 PM
RE: Repurpose a Philco - by shaler78 - 04-10-2013, 04:41 PM
RE: Repurpose a Philco - by Phlogiston - 04-10-2013, 07:49 PM
RE: Repurpose a Philco - by TimC - 04-10-2013, 09:10 PM
RE: Repurpose a Philco - by Arran - 04-10-2013, 09:38 PM
RE: Repurpose a Philco - by GarySP - 04-10-2013, 10:03 PM
RE: Repurpose a Philco - by Arran - 04-10-2013, 10:59 PM
RE: Repurpose a Philco - by gary rabbitt - 04-11-2013, 03:56 PM
RE: Repurpose a Philco - by DeckApe - 04-13-2013, 10:55 AM
Philco 91 Tuning Condenser
There are currently 6513 online users. [Complete List]
» 1 Member(s) | 6512 Guest(s)
