  • 1 Vote(s) - 5 Average
60 MB restoration
Interesting, that's the same control shaft that's missing on my Philco 3118, those switches must have that as a weak point? I was debating on whether to replace it with another switch or a linear tapered pot, the pot would not be original but it would allow more variation then high or low. That set probably needs more work then your 60MB but since I found out that it's cabinet was different then the U.S 118B I would like to fix it up.
60 MB restoration - by Bob Andersen - 04-11-2013, 04:39 PM
RE: 60 MB restoration - by Bob Andersen - 04-11-2013, 04:43 PM
RE: 60 MB restoration - by Arran - 04-11-2013, 11:14 PM
RE: 60 MB restoration - by Bob Andersen - 04-11-2013, 11:24 PM
RE: 60 MB restoration - by Arran - 04-11-2013, 11:33 PM
RE: 60 MB restoration - by jph14 - 04-12-2013, 07:19 AM
RE: 60 MB restoration - by Bob Andersen - 04-12-2013, 01:20 PM
RE: 60 MB restoration - by Bob Andersen - 04-12-2013, 06:15 PM
RE: 60 MB restoration - by Bob Andersen - 04-14-2013, 02:07 PM
RE: 60 MB restoration - by Bob Andersen - 04-15-2013, 12:03 AM
RE: 60 MB restoration - by Bob Andersen - 04-15-2013, 12:32 PM
RE: 60 MB restoration - by Bob Andersen - 04-16-2013, 09:40 PM
RE: 60 MB restoration - by Chuck Schwark - 04-17-2013, 09:11 AM
RE: 60 MB restoration - by Bob Andersen - 04-17-2013, 02:52 PM
RE: 60 MB restoration - by Bob Andersen - 04-17-2013, 09:27 PM
RE: 60 MB restoration - by Art Hoch - 04-18-2013, 12:05 PM
RE: 60 MB restoration - by Bob Andersen - 04-22-2013, 08:57 PM
RE: 60 MB restoration - by Bob Andersen - 04-23-2013, 02:18 PM
RE: 60 MB restoration - by w4rtc - 04-23-2013, 04:00 PM
RE: 60 MB restoration - by Arran - 04-23-2013, 10:12 PM
RE: 60 MB restoration - by Bob Andersen - 04-23-2013, 10:30 PM
RE: 60 MB restoration - by Arran - 04-23-2013, 11:34 PM
RE: 60 MB restoration - by Bob Andersen - 09-01-2013, 12:24 AM
RE: 60 MB restoration - by Radioroslyn - 09-01-2013, 08:39 AM
RE: 60 MB restoration - by Bob Andersen - 10-22-2013, 12:57 PM
RE: 60 MB restoration - by Ron Ramirez - 10-22-2013, 07:36 PM
RE: 60 MB restoration - by Bob Andersen - 10-22-2013, 10:19 PM
RE: 60 MB restoration - by Bob Andersen - 10-24-2013, 01:28 AM
RE: 60 MB restoration - by Bob Andersen - 10-28-2013, 09:37 PM
RE: 60 MB restoration - by don'tdomelikethat - 10-29-2013, 10:31 AM
RE: 60 MB restoration - by Bob Andersen - 10-29-2013, 01:03 PM
RE: 60 MB restoration - by Bob Andersen - 10-30-2013, 12:57 AM
RE: 60 MB restoration - by Bob Andersen - 11-01-2013, 12:34 AM
RE: 60 MB restoration - by Arran - 11-01-2013, 02:13 AM
RE: 60 MB restoration - by Bob Andersen - 11-01-2013, 11:53 AM
RE: 60 MB restoration - by w4rtc - 11-01-2013, 04:43 PM
There are currently 9917 online users. [Complete List]
» 3 Member(s) | 9914 Guest(s)
