Philco 38-62 cabinet restoration
Just common bleach. I think it was water stains and mildew on this cabinet.
RE: Philco 38-62 cabinet restoration - by Arran - 03-13-2013, 11:56 PM
RE: Philco 38-62 cabinet restoration - by Arran - 03-15-2013, 12:27 AM
RE: Philco 38-62 cabinet restoration - by Arran - 03-16-2013, 07:26 PM
RE: Philco 38-62 cabinet restoration - by Arran - 04-12-2013, 01:13 AM
RE: Philco 38-62 cabinet restoration - by Bob Andersen - 04-12-2013, 01:11 PM
RE: Philco 38-62 cabinet restoration - by Arran - 04-15-2013, 07:55 PM
RE: Philco 38-62 cabinet restoration - by Walston - 05-11-2013, 07:50 AM
RE: Philco 38-62 cabinet restoration - by morzh - 05-24-2013, 09:21 PM
RE: Philco 38-62 cabinet restoration - by morzh - 05-24-2013, 10:19 PM
RE: Philco 38-62 cabinet restoration - by Arran - 05-25-2013, 01:39 AM
There are currently 10504 online users. [Complete List]
» 4 Member(s) | 10500 Guest(s)
AvatarAvatarAvatarAvatar
