Periodic Volume Drop-and-Pop
I am also wondering if this may be caused by the volume control rheostat. I haven't touched it yet, but am wondering if there is something I can do to "clean" it up.
Periodic Volume Drop-and-Pop - by Guest - 12-02-2007, 01:43 PM
[No subject] - by Guest - 12-03-2007, 12:01 PM
Drop off and ..... - by AI2V - 12-03-2007, 04:13 PM
[No subject] - by Guest - 12-03-2007, 04:24 PM
[No subject] - by Chuck Schwark - 12-03-2007, 05:34 PM
[No subject] - by Guest - 12-04-2007, 06:31 PM
[No subject] - by Chuck Schwark - 12-04-2007, 10:23 PM
[No subject] - by Guest - 12-10-2007, 06:21 PM
[No subject] - by Guest - 12-16-2007, 01:53 AM
Philco 91 Tuning Condenser
There are currently 9145 online users. [Complete List]
» 1 Member(s) | 9144 Guest(s)
