Philco 38-690 restoration
I disassembled it yesterday, and will strip the cabinet today.
The hack(s) who worked on it previously paralled new electrolytics with the old, and I found large long strands of solder in the radio chassis!
These pieces are removed to allow removal of the tambour:
[Image: http://i269.photobucket.com/albums/jj77/.../010-4.jpg]
The bottom of the power supply and amplifier chassis - note paralled electrolytics:
[Image: http://i269.photobucket.com/albums/jj77/...003-17.jpg]
The bottom of the radio chassis:
[Image: http://i269.photobucket.com/albums/jj77/...004-16.jpg]
Long loose pieces of solder in the radio chassis:
[Image: http://i269.photobucket.com/albums/jj77/.../009-7.jpg]
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Philco 38-690 restoration - by FStephenMasek - 04-18-2011, 09:30 PM
RE: Philco 38-690 restoration - by FStephenMasek - 04-13-2013, 12:47 PM
RE: Philco 38-690 restoration - by FStephenMasek - 04-13-2013, 09:16 PM
RE: Philco 38-690 restoration - by morzh - 04-13-2013, 09:22 PM
RE: Philco 38-690 restoration - by FStephenMasek - 02-17-2014, 12:35 PM
RE: Philco 38-690 restoration - by morzh - 02-17-2014, 12:43 PM
RE: Philco 38-690 restoration - by FStephenMasek - 02-17-2014, 10:13 PM
RE: Philco 38-690 restoration - by morzh - 02-17-2014, 10:16 PM
RE: Philco 38-690 restoration - by FStephenMasek - 06-22-2014, 12:04 AM
RE: Philco 38-690 restoration - by morzh - 06-22-2014, 10:56 AM
RE: Philco 38-690 restoration - by FStephenMasek - 06-22-2014, 01:01 PM
RE: Philco 38-690 restoration - by FStephenMasek - 06-22-2014, 07:18 PM
RE: Philco 38-690 restoration - by morzh - 06-22-2014, 08:44 PM
RE: Philco 38-690 restoration - by gregb - 06-22-2014, 08:47 PM
RE: Philco 38-690 restoration - by PhilcoJohn - 06-23-2014, 05:47 PM
RE: Philco 38-690 restoration - by morzh - 06-23-2014, 05:53 PM
RE: Philco 38-690 restoration - by FStephenMasek - 07-06-2014, 01:40 PM
RE: Philco 38-690 restoration - by morzh - 07-06-2014, 02:13 PM
RE: Philco 38-690 restoration - by FStephenMasek - 07-06-2014, 02:46 PM
RE: Philco 38-690 restoration - by morzh - 07-06-2014, 02:51 PM
RE: Philco 38-690 restoration - by FStephenMasek - 07-10-2014, 04:32 PM
RE: Philco 38-690 restoration - by morzh - 07-10-2014, 05:32 PM
RE: Philco 38-690 restoration - by FStephenMasek - 11-06-2014, 01:27 AM
RE: Philco 38-690 restoration - by sam - 11-06-2014, 03:57 AM
RE: Philco 38-690 restoration - by 462ron - 11-06-2014, 01:13 PM
RE: Philco 38-690 restoration - by klondike98 - 11-06-2014, 02:08 PM
RE: Philco 38-690 restoration - by morzh - 11-06-2014, 02:35 PM
RE: Philco 38-690 restoration - by FStephenMasek - 11-11-2014, 12:57 PM
RE: Philco 38-690 restoration - by morzh - 11-11-2014, 01:17 PM
Re: Philco 38-690 restoration - by Ron Ramirez - 04-19-2011, 10:07 AM
Re: Philco 38-690 restoration - by FStephenMasek - 04-19-2011, 12:59 PM
Re: Philco 38-690 restoration - by Ron Ramirez - 04-19-2011, 02:00 PM
Re: Philco 38-690 restoration - by FStephenMasek - 04-19-2011, 02:35 PM
Re: Philco 38-690 restoration - by Ron Ramirez - 04-19-2011, 02:47 PM
Re: Philco 38-690 restoration - by FStephenMasek - 04-20-2011, 10:47 PM
Re: Philco 38-690 restoration - by Ron Ramirez - 04-21-2011, 07:41 AM
Re: Philco 38-690 restoration - by FStephenMasek - 04-26-2011, 10:06 PM
There are currently 10219 online users. [Complete List]
» 3 Member(s) | 10216 Guest(s)
