Huh? I lost the signal over 1200 AM on my 42-355!
Thanks, codefox1, that's exactly what it must've been. After I cleaned out the variable capacitor, it worked like a charm. It was strange how it happened... I was listening to it this morning and it worked fine. Went to turn it back on after lunch and it was dead on the upper end of the dial. Oh well, it gave me a chance to finally set the pushbuttons to a few local stations that I'd been meaning to do for some time now, so all was not lost. I appreciate your help!
RE: Huh? I lost the signal over 1200 AM on my 42-355! - by NostalgiaRadioTime - 04-13-2013, 10:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
