Help Identifying radio
i'm keeping my fingers crossed that my family has the dial escutcheon somewhere as they thought it was on there originally when we got it. as for the grillle pattern, how would you recommend I go about finding another to make the pattern from?
Help Identifying radio - by bjaiello - 04-13-2013, 01:47 PM
RE: Help Identifying radio - by TA Forbes - 04-13-2013, 09:04 PM
RE: Help Identifying radio - by bjaiello - 04-13-2013, 10:02 PM
RE: Help Identifying radio - by bjaiello - 04-13-2013, 10:36 PM
RE: Help Identifying radio - by Arran - 04-13-2013, 11:17 PM
RE: Help Identifying radio - by bjaiello - 04-13-2013, 11:41 PM
RE: Help Identifying radio - by Tim Tress - 06-19-2013, 07:27 PM
There are currently 5723 online users. [Complete List]
» 2 Member(s) | 5721 Guest(s)
