RCA 56X2 Output Transformer
Looking at the tube data sheet, the normal plate current is about 41 mA, so your transformer needs to have at least this primary current rating. This is confirmed from the schematic where it shows the cathode voltage at 5.6V. Using Ohms law, this gives a total cathode current of 5.6/120 ohms, or about 46 Ma, which includes a few mA of screen grid current.
The schematic shows a transformer secondary impedance of 3.4 ohms, so your replacement transformer should have a 3 to 4 ohm spec. So what you are looking for is a transformer with a 2500 ohm primary and a 3-4 ohm secondary with a 40+ mA current rating. The actual DC resistances are not really significant if these specs are met.
RCA 56X2 Output Transformer - by Raleigh - 04-12-2013, 01:14 PM
RE: RCA 56X2 Output Transformer - by BrendaAnnD - 04-12-2013, 03:49 PM
RE: RCA 56X2 Output Transformer - by Raleigh - 04-12-2013, 05:17 PM
RE: RCA 56X2 Output Transformer - by BrendaAnnD - 04-12-2013, 07:55 PM
RE: RCA 56X2 Output Transformer - by Raleigh - 04-12-2013, 10:30 PM
RE: RCA 56X2 Output Transformer - by Mondial - 04-12-2013, 11:14 PM
RE: RCA 56X2 Output Transformer - by BrendaAnnD - 04-13-2013, 01:19 AM
RE: RCA 56X2 Output Transformer - by 7estatdef - 04-13-2013, 03:22 PM
RE: RCA 56X2 Output Transformer - by Raleigh - 04-13-2013, 05:56 PM
RE: RCA 56X2 Output Transformer - by Arran - 04-14-2013, 12:01 AM
RE: RCA 56X2 Output Transformer - by Mondial - 04-14-2013, 08:55 AM
RE: RCA 56X2 Output Transformer - by codefox1 - 04-14-2013, 12:13 PM
RE: RCA 56X2 Output Transformer - by Raleigh - 04-14-2013, 10:37 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
There are currently 1662 online users. [Complete List]
» 5 Member(s) | 1657 Guest(s)
AvatarAvatarAvatarAvatar
