Does anyone have any info they could share?
Hi there.
I'm new to the forum so I'm hoping I'm following protocol.
I inherited an old Philco console Radio with a turntable several years ago. The radio was made in the early 50's in Toronto Canada. The model number on the cabinet is 730 which also matches the chassis number on the radio. On the cabinet it says "Model No." and on the metal chassis it says "Chassis No.". Anyhow.. I have searched high and low and cannot find a thing about this unit on the net. I've restored the cabinet but it just won't be right if I can't restore the radio.
I'd appreciate any help you can give me.
Does anyone have any info they could share? - by Guest - 12-03-2007, 09:52 PM
[No subject] - by Ron Ramirez - 12-03-2007, 10:42 PM
[No subject] - by Carl Travis - 12-03-2007, 11:15 PM
[No subject] - by Ron Ramirez - 12-03-2007, 11:31 PM
[No subject] - by Guest - 12-03-2007, 11:34 PM
Philco 91 Tuning Condenser
There are currently 4618 online users. [Complete List]
» 2 Member(s) | 4616 Guest(s)
