Don't want to damage the coils...
Hi Greg
Some pics would be very helpful. Would not use deoxit. I would try to clean it with a vacuum and a soft brush.
RE: Don't want to damage the coils... - by 7estatdef - 04-14-2013, 06:53 PM
