Does anyone have any info they could share?
Hello and welcome.
I'm afraid I can't help you, since I have very little info on Canadian Philco radios. The Canadian models began to use different model numbers from their US counterparts in 1939, and some Canadian Philcos are quite different than USA models.
So you will need info from someone in Canada, or someone who has Canadian Philco info.
Does anyone have any info they could share? - by Guest - 12-03-2007, 09:52 PM
[No subject] - by Ron Ramirez - 12-03-2007, 10:42 PM
[No subject] - by Carl Travis - 12-03-2007, 11:15 PM
[No subject] - by Ron Ramirez - 12-03-2007, 11:31 PM
[No subject] - by Guest - 12-03-2007, 11:34 PM
Philco 91 Tuning Condenser
There are currently 10217 online users. [Complete List]
» 3 Member(s) | 10214 Guest(s)
