116x Restoration
Tone control issue.
In two of the positions the tone control works as it should, in the other two positions the sound will squeal, high high pitch. There are two 4meg resistors that are measuring 5.2meg. Im going to swap these for 3.9meg.
Anyone have any idea what I should check? I have replaced all the caps with the proper values except the mica's.
[Image: http://i1129.photobucket.com/albums/m501...b33490.jpg]
Thanks
-Keith
116x Restoration - by ipwizard - 04-04-2013, 01:53 AM
RE: 116x Restoration - by morzh - 04-04-2013, 11:43 AM
RE: 116x Restoration - by ipwizard - 04-05-2013, 12:21 AM
RE: 116x Restoration - by morzh - 04-05-2013, 03:11 PM
RE: 116x Restoration - by 7estatdef - 04-05-2013, 03:55 PM
RE: 116x Restoration - by ipwizard - 04-05-2013, 05:30 PM
RE: 116x Restoration - by Ron Ramirez - 04-05-2013, 09:18 PM
RE: 116x Restoration - by 7estatdef - 04-05-2013, 11:08 PM
RE: 116x Restoration - by codefox1 - 04-06-2013, 08:24 AM
RE: 116x Restoration - by ipwizard - 04-06-2013, 12:58 PM
RE: 116x Restoration - by ipwizard - 04-09-2013, 11:44 AM
RE: 116x Restoration - by ipwizard - 04-15-2013, 05:25 PM
RE: 116x Restoration - by Mondial - 04-15-2013, 09:04 PM
RE: 116x Restoration - by 7estatdef - 04-15-2013, 09:40 PM
RE: 116x Restoration - by ipwizard - 04-16-2013, 02:37 AM
RE: 116x Restoration - by ipwizard - 05-14-2013, 12:48 AM
RE: 116x Restoration - by BrendaAnnD - 05-14-2013, 01:10 AM
RE: 116x Restoration - by 7estatdef - 05-14-2013, 06:51 AM
RE: 116x Restoration - by Chuck Schwark - 05-14-2013, 09:05 AM
RE: 116x Restoration - by ipwizard - 05-14-2013, 11:16 AM
RE: 116x Restoration - by Chuck Schwark - 05-14-2013, 01:03 PM
RE: 116x Restoration - by BrendaAnnD - 05-14-2013, 03:49 PM
RE: 116x Restoration - by Chuck Schwark - 05-14-2013, 09:05 PM
RE: 116x Restoration - by Mondial - 05-14-2013, 10:26 PM
RE: 116x Restoration - by ipwizard - 05-15-2013, 06:25 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6701 online users. [Complete List]
» 1 Member(s) | 6700 Guest(s)
