Model 41-296 LO problem - BC band
Both good suggestions. I have the variable out now, soaking in Simple Green and hot water. Wasn't as clean as I thought it was, as the solution is already muddy looking... I will use distilled water as a final rinse on it. Will be tomorrow before I'm done with that and reinstall it.
That bandswitch is a booger, and hard to see and get to all the contacts. While the tuning condensor is soaking, I will see if I can get better access to some of those contacts with something. I am out of deoxit, so may need to get some for this. I used regular contact cleaner, but don't think it's up to the job. I am still baffled about the LO frequencies I'm seeing. Makes no sense...
Model 41-296 LO problem - BC band - by w5ami - 04-15-2013, 06:45 PM
RE: Model 41-296 LO problem - BC band - by w5ami - 04-15-2013, 08:54 PM
RE: Model 41-296 LO problem - BC band - by w5ami - 04-16-2013, 10:54 AM
RE: Model 41-296 LO problem - BC band - by w5ami - 04-16-2013, 10:16 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6977 online users. [Complete List]
» 1 Member(s) | 6976 Guest(s)
