Philco 38-62 cabinet restoration
The traces of original finish left weren't quite so dark or opaque as my mid-30s tombstones. I do have some dye based extra dark walnut lacquer though and I'll give it a try tomorrow.
RE: Philco 38-62 cabinet restoration - by Arran - 03-13-2013, 11:56 PM
RE: Philco 38-62 cabinet restoration - by Arran - 03-15-2013, 12:27 AM
RE: Philco 38-62 cabinet restoration - by Arran - 03-16-2013, 07:26 PM
RE: Philco 38-62 cabinet restoration - by Arran - 04-12-2013, 01:13 AM
RE: Philco 38-62 cabinet restoration - by Arran - 04-15-2013, 07:55 PM
RE: Philco 38-62 cabinet restoration - by Bob Andersen - 04-15-2013, 09:39 PM
RE: Philco 38-62 cabinet restoration - by Walston - 05-11-2013, 07:50 AM
RE: Philco 38-62 cabinet restoration - by morzh - 05-24-2013, 09:21 PM
RE: Philco 38-62 cabinet restoration - by morzh - 05-24-2013, 10:19 PM
RE: Philco 38-62 cabinet restoration - by Arran - 05-25-2013, 01:39 AM
