Model 41-296 LO problem - BC band
Found the problem! Misplaced wire from A10 (on band switch) to lug 1 on the Osc coil. It should have been placed on lug #3 of the coil. Boy, what odd things can happen with one wire. It came alive better than I expected it to! Sensitive and not bad on selectivity.
Thanks for all the suggestions!
Brian
Model 41-296 LO problem - BC band - by w5ami - 04-15-2013, 06:45 PM
RE: Model 41-296 LO problem - BC band - by w5ami - 04-15-2013, 08:54 PM
RE: Model 41-296 LO problem - BC band - by w5ami - 04-16-2013, 10:54 AM
RE: Model 41-296 LO problem - BC band - by w5ami - 04-16-2013, 10:16 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 3581 online users. [Complete List]
» 1 Member(s) | 3580 Guest(s)
