Model 29 Questions
Gentleman
I have a Philco model 28 cabinet with a 29 chassis. Got the tech data from Chuck Schwark (nice big prints I can read) . Here is some info, most of the chassis looks undisturbed but the filter cap #64 shows to be a three stage 8,8,10 mf now what was in there were two 8's the 10 is missing, also the can itself is mounted on the top side but is insulated( paper wrap) from the clamp holding it in place. There is a lead from the cap case (under chassis) ground that goes to #57
Chuck has marked the polarity for me on the print so my questions are.
1 Could it work with out the 10? Has it been working?
2 In the print the polarity of the 10 the neg is tied to the neg of the two 8's and the pos of the 10 goes to the chassis. How does this work?
http://www.nostalgiaair.org/PagesByModel...013181.pdf
Want to understand what is going on electrically
Thanks Eric
Model 29 Questions - by Eric - 04-17-2013, 04:58 PM
RE: Model 29 Questions - by 7estatdef - 04-17-2013, 08:15 PM
RE: Model 29 Questions - by BrendaAnnD - 04-17-2013, 08:16 PM
RE: Model 29 Questions - by Eric - 04-17-2013, 08:53 PM
RE: Model 29 Questions - by Eric - 04-19-2013, 06:06 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2962 online users. [Complete List]
» 3 Member(s) | 2959 Guest(s)
