Model 29 Questions
Thanks for the info I intend to put the 10uf in just was wondering why it wasn't and in my limited exp never saw this config before. Just a few more caps and resistors and it will be test time!
Eric
Model 29 Questions - by Eric - 04-17-2013, 04:58 PM
RE: Model 29 Questions - by 7estatdef - 04-17-2013, 08:15 PM
RE: Model 29 Questions - by BrendaAnnD - 04-17-2013, 08:16 PM
RE: Model 29 Questions - by Eric - 04-17-2013, 08:53 PM
RE: Model 29 Questions - by Eric - 04-19-2013, 06:06 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
