Self Osc in output on 41-296
Bad news... Looks like one side of the audio xfmr going to the 41's is open, so I only have voltage on one 41 right now. I suspect his could be causing my problem, among other things. I knew the audio seemed a lot more distorted than I expected. Dang!
So, let me ask another question. What is a good replacement for this audio xfmr, and where would I find one? Hammond?
Brian
Self Osc in output on 41-296 - by w5ami - 04-17-2013, 04:06 PM
RE: Self Osc in output on 41-296 - by morzh - 04-17-2013, 06:19 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-17-2013, 08:14 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-17-2013, 08:21 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-17-2013, 09:21 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-17-2013, 10:03 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-18-2013, 06:38 AM
RE: Self Osc in output on 41-296 - by w5ami - 04-18-2013, 06:55 AM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-18-2013, 09:39 AM
RE: Self Osc in output on 41-296 - by w5ami - 04-18-2013, 09:47 AM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-18-2013, 04:20 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-21-2013, 03:08 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-21-2013, 03:26 PM
RE: Self Osc in output on 41-296 - by Raleigh - 04-22-2013, 04:28 PM
RE: Self Osc in output on 41-296 - by 7estatdef - 04-22-2013, 05:06 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-22-2013, 05:35 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-22-2013, 07:47 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-22-2013, 07:57 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-22-2013, 08:36 PM
RE: Self Osc in output on 41-296 - by Mondial - 04-22-2013, 08:50 PM
RE: Self Osc in output on 41-296 - by 7estatdef - 04-22-2013, 09:19 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-22-2013, 10:21 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-23-2013, 01:42 AM
RE: Self Osc in output on 41-296 - by Raleigh - 04-23-2013, 02:57 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-23-2013, 03:05 PM
RE: Self Osc in output on 41-296 - by Raleigh - 04-23-2013, 04:35 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
