46-1209 (Code 121) - A real "fixer"
Actually the wooden escutcheon was never stained on these sets, they used a coloured lacquer over the white wood, I think that medium walnut tone spray might be closest.
RE: 46-1209 (Code 121) - A real "fixer" - by Arran - 04-18-2013, 12:23 AM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 3527 online users. [Complete List]
» 1 Member(s) | 3526 Guest(s)
