Philco 16B Dial Warped - Any Fix?
If the spare dial doesn't work out you may want to google how the vinyl guys fix warped LP's. Something about low temps in the oven between two sheets of glass and letting it cool slowly overnight.
Good luck,
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Philco 16B Dial Warped - Any Fix? - by davemc - 04-17-2013, 04:09 PM
RE: Philco 16B Dial Warped - Any Fix? - by PhilcoMike - 04-18-2013, 11:27 AM
RE: Philco 16B Dial Warped - Any Fix? - by davemc - 04-18-2013, 01:11 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
