Philco 38-62 cabinet restoration
I wrapped up the toner and put on a couple coats of clear gloss this afternoon. I knew I was taking a chance because of the high humidity levels, but I really wanted to get it done.
Luckily, just a minimal amount of blushing in the clear coat that I expect will sand out.
[Image: http://farm9.staticflickr.com/8265/86618...9143_c.jpg]
The scar where I repaired the split is barely visible in very bright light.
[Image: http://farm9.staticflickr.com/8241/86607...658a_c.jpg]
I'll let it cure for a week or two, then sand with 600 grit and spray on a couple more coats.
If I had to do it again, I would have gone a little bit lighter on the body. Maybe one or two less coats of the extra dark walnut.
[Image: http://farm9.staticflickr.com/8246/86607...3a8c_c.jpg]
RE: Philco 38-62 cabinet restoration - by Arran - 03-13-2013, 11:56 PM
RE: Philco 38-62 cabinet restoration - by Arran - 03-15-2013, 12:27 AM
RE: Philco 38-62 cabinet restoration - by Arran - 03-16-2013, 07:26 PM
RE: Philco 38-62 cabinet restoration - by Arran - 04-12-2013, 01:13 AM
RE: Philco 38-62 cabinet restoration - by Arran - 04-15-2013, 07:55 PM
RE: Philco 38-62 cabinet restoration - by Bob Andersen - 04-18-2013, 06:51 PM
RE: Philco 38-62 cabinet restoration - by Walston - 05-11-2013, 07:50 AM
RE: Philco 38-62 cabinet restoration - by morzh - 05-24-2013, 09:21 PM
RE: Philco 38-62 cabinet restoration - by morzh - 05-24-2013, 10:19 PM
RE: Philco 38-62 cabinet restoration - by Arran - 05-25-2013, 01:39 AM
