Philco Model 131?
Is this model Canadian? Here is the info I have.
PHILCO MODEL 131, 4 TUBES, AM BAND, BATTERY OPERATED. I can not find any info on it.
thanks
Chris
Philco Model 131? - by Chris Drumma - 12-07-2007, 02:12 PM
[No subject] - by Chuck Schwark - 12-07-2007, 02:49 PM
[No subject] - by Chris Drumma - 12-07-2007, 03:07 PM
[No subject] - by Chuck Schwark - 12-07-2007, 04:30 PM
[No subject] - by Chris Drumma - 12-07-2007, 06:00 PM
[No subject] - by Chuck Schwark - 12-07-2007, 06:41 PM
[No subject] - by Chris Drumma - 12-11-2007, 09:14 AM
[No subject] - by Ron Ramirez - 12-19-2007, 10:57 AM
[No subject] - by Chris Drumma - 12-19-2007, 04:00 PM
[No subject] - by Ron Ramirez - 12-19-2007, 04:43 PM
[No subject] - by Chris Drumma - 12-19-2007, 06:33 PM
