Philco Model 131?
Chuck here is a picture of it. I could not find pictures of it in Ron's book.
http://cgi.ebay.com/270184185168
Any help would be appreciated.
Chris
Philco Model 131? - by Chris Drumma - 12-07-2007, 02:12 PM
[No subject] - by Chuck Schwark - 12-07-2007, 02:49 PM
[No subject] - by Chris Drumma - 12-07-2007, 03:07 PM
[No subject] - by Chuck Schwark - 12-07-2007, 04:30 PM
[No subject] - by Chris Drumma - 12-07-2007, 06:00 PM
[No subject] - by Chuck Schwark - 12-07-2007, 06:41 PM
[No subject] - by Chris Drumma - 12-11-2007, 09:14 AM
[No subject] - by Ron Ramirez - 12-19-2007, 10:57 AM
[No subject] - by Chris Drumma - 12-19-2007, 04:00 PM
[No subject] - by Ron Ramirez - 12-19-2007, 04:43 PM
[No subject] - by Chris Drumma - 12-19-2007, 06:33 PM
Philco 91 Tuning Condenser
There are currently 10522 online users. [Complete List]
» 2 Member(s) | 10520 Guest(s)
