Crosley 88TC
Started on Crosley 88TC. What is the wattage of resistor #52? ( wirewound two section, 80 and 18 ohm) This is enclosed in a metal tube on top of chassis. Thanks for the help.
Joe
http://www.nostalgiaair.org/resources/650/M0003650.htm
Crosley 88TC - by jph14 - 04-20-2013, 05:55 PM
RE: Crosley 88TC - by BrendaAnnD - 04-20-2013, 07:29 PM
RE: Crosley 88TC - by jph14 - 04-23-2013, 01:37 PM
