Model 118 Cap question
I've seen those with micas inside...but most of them I've opened up had tiny paper caps inside! Icon_eek
You'd better rebuild it, too. Better safe than sorry!
Model 118 Cap question - by jerryhawthorne - 04-20-2013, 02:48 PM
RE: Model 118 Cap question - by Chris Cusick - 04-20-2013, 03:04 PM
RE: Model 118 Cap question - by jerryhawthorne - 04-20-2013, 03:13 PM
RE: Model 118 Cap question - by 7estatdef - 04-20-2013, 08:33 PM
RE: Model 118 Cap question - by Ron Ramirez - 04-20-2013, 08:51 PM
RE: Model 118 Cap question - by jerryhawthorne - 04-20-2013, 09:35 PM
RE: Model 118 Cap question - by BrendaAnnD - 04-20-2013, 10:26 PM
RE: Model 118 Cap question - by jerryhawthorne - 04-20-2013, 11:12 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
