37-630?
I like working on them. Probably because I have worked on a lot of them. If you think that one is bad, a 37-116 will give you nightmares.
Even though it does not look like it, I'll bet that sub-chassis made assembly line construction faster/better, especially when it comes to some of the larger units like the 37-116.
On the less complicated units, say, the 37-620 and down, you can most often recap them in place. Starting around the 37-630, it is easier to pull out the sub-chassis.
37-630? - by Skip - 04-21-2013, 12:07 AM
RE: 37-630? - by shaler78 - 04-21-2013, 01:51 AM
RE: 37-630? - by Arran - 04-21-2013, 02:54 AM
RE: 37-630? - by Skip - 04-21-2013, 08:41 AM
RE: 37-630? - by Phlogiston - 04-21-2013, 10:47 AM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2754 online users. [Complete List]
» 1 Member(s) | 2753 Guest(s)
