1940 Coronado C800 console- COMPLETED!
Thanks guys! I hope Sparker who posted about his great-grandmothers' Philco sees this thread and thinks twice about disposing of the radio.
This Coronado uses a similar clear plastic dial cover like the 1939 Philcos used (which today are usually always cracked, dark yellow in color, or have pieces missing out of them). I managed to salvage this one and it's still crystal clear!
There are currently 5081 online users. [Complete List]
» 1 Member(s) | 5080 Guest(s)
