Which Aerial / Antenna to use?
For those who have a long wire antennas I would be interested in how everybody has set up their antenna. The old diagrams I have found call out the use of a lighting arrestor. What if any kinds of lightning protection are you using? I have posted the articles I have found. I would like to build a longwire antenna but do not want my house struck by lightning.
http://www.synchrophase.info/Articles/gr...o2508.html
http://www.angelfire.com/mb/amandx/longwire.html
http://www.moonlightsys.com/otr/antenna.html
http://www.techlib.com/electronics/antennas.html
http://www.abc.net.au/reception/radio/am...#long_wire
http://members.aol.com/djadamson7/articl...enna1.html
Which Aerial / Antenna to use? - by philcobenz - 12-09-2007, 05:34 PM
[No subject] - by 49Stude63 - 12-09-2007, 10:23 PM
[No subject] - by Guest - 12-10-2007, 10:06 PM
[No subject] - by 49Stude63 - 12-10-2007, 11:20 PM
Ok, let's try again - by philcobenz - 06-10-2008, 06:32 PM
[No subject] - by PhilcoPhil - 06-10-2008, 06:57 PM
[No subject] - by philcobenz - 06-10-2008, 08:53 PM
[No subject] - by exray - 06-10-2008, 08:59 PM
[No subject] - by Ron Ramirez - 06-10-2008, 11:07 PM
[No subject] - by philcobenz - 06-11-2008, 12:01 PM
[No subject] - by exray - 06-11-2008, 05:27 PM
[No subject] - by phly guy - 06-13-2008, 09:26 AM
[No subject] - by philcobenz - 06-15-2008, 03:13 AM
