  • 1 Vote(s) - 2 Average
1936 Philco 645
Looks good!!! Just cleaned up one myself for 116. Boy I couldn't believe all the dirt that came off of it. It also has a crack in it. I've found that taping it from the back side with some clear packing tape works wonders and is pretty invisible. Also if you don't like the color so much you can put a little bit of water base paint on the bulb to tint it a bit if it seems too bright or too yellow or whatever.
1936 Philco 645 - by Ronin61 - 03-23-2013, 10:33 PM
RE: 1936 Philco 645 - by morzh - 03-23-2013, 11:48 PM
RE: 1936 Philco 645 - by 7estatdef - 03-24-2013, 08:58 AM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 11:05 AM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 02:21 PM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 02:38 PM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 02:39 PM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 02:41 PM
RE: 1936 Philco 645 - by 7estatdef - 03-24-2013, 04:06 PM
RE: 1936 Philco 645 - by Ronin61 - 03-26-2013, 04:13 PM
RE: 1936 Philco 645 - by 7estatdef - 03-27-2013, 08:38 AM
RE: 1936 Philco 645 - by morzh - 03-27-2013, 12:15 PM
RE: 1936 Philco 645 - by codefox1 - 03-28-2013, 04:34 AM
RE: 1936 Philco 645 - by Ronin61 - 04-07-2013, 09:30 PM
RE: 1936 Philco 645 - by 7estatdef - 04-10-2013, 06:27 PM
RE: 1936 Philco 645 - by Ronin61 - 04-11-2013, 04:58 PM
RE: 1936 Philco 645 - by Ronin61 - 04-22-2013, 10:57 AM
RE: 1936 Philco 645 - by 7estatdef - 04-22-2013, 05:13 PM
RE: 1936 Philco 645 - by Winky Dink - 02-02-2014, 05:57 PM
RE: 1936 Philco 645 - by Mondial - 02-02-2014, 06:15 PM
RE: 1936 Philco 645 - by Winky Dink - 02-02-2014, 06:32 PM
RE: 1936 Philco 645 - by Winky Dink - 02-02-2014, 11:20 PM
RE: 1936 Philco 645 - by Mondial - 02-03-2014, 01:07 AM
RE: 1936 Philco 645 - by Winky Dink - 02-03-2014, 03:43 AM
RE: 1936 Philco 645 - by Mondial - 02-03-2014, 09:24 AM
RE: 1936 Philco 645 - by Ron Ramirez - 02-03-2014, 11:27 AM
RE: 1936 Philco 645 - by Winky Dink - 02-03-2014, 07:35 PM
RE: 1936 Philco 645 - by Winky Dink - 02-04-2014, 01:00 AM
RE: 1936 Philco 645 - by Winky Dink - 03-24-2014, 10:10 AM
RE: 1936 Philco 645 - by codefox1 - 03-24-2014, 10:52 AM
RE: 1936 Philco 645 - by Winky Dink - 03-24-2014, 11:41 AM
