Odd Heater String 116X
Mondial
Not trying to belabor the point but would there be a difference between the 2A3 and the 6A3? As they both require about the same amount of power the operate the filament. 2.5v at a higher current or 6.3v at a lower current. I'm not much of a rocket scientist, some times the simplest things stump me!!
Odd Heater String 116X - by 7estatdef - 04-19-2013, 09:22 PM
RE: Odd Heater String 116X - by codefox1 - 04-20-2013, 03:54 AM
RE: Odd Heater String 116X - by Mondial - 04-20-2013, 08:48 AM
RE: Odd Heater String 116X - by ipwizard - 04-20-2013, 10:04 AM
RE: Odd Heater String 116X - by 7estatdef - 04-20-2013, 08:22 PM
RE: Odd Heater String 116X - by Mondial - 04-20-2013, 10:09 PM
RE: Odd Heater String 116X - by 7estatdef - 04-21-2013, 02:01 PM
RE: Odd Heater String 116X - by 7estatdef - 04-22-2013, 05:24 PM
RE: Odd Heater String 116X - by Mondial - 04-22-2013, 06:37 PM
RE: Odd Heater String 116X - by 7estatdef - 04-22-2013, 09:12 PM
RE: Odd Heater String 116X - by Mondial - 04-22-2013, 10:23 PM
RE: Odd Heater String 116X - by chris25260880 - 04-23-2013, 11:23 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
