Philco Tone Control 635
I need some help with the tone control on my Philco 635 chassis. (table model set). I removed what looks like a single capacitor from the tone control. I believe that each end of the capacitor was connected to the two terminals that are on the control, but am not sure if this is correct. I also am not sure of what the value of the capacitor was.
The wiring on this set was messed with, and I do not know which lead connects to where.
I would appreciate any help in connecting this tone control to the circut, and also, what value part should be in the control itself.
Frank.
Philco Tone Control 635 - by Frank - 12-11-2007, 09:37 AM
[No subject] - by Carl Travis - 12-11-2007, 09:46 AM
[No subject] - by Frank - 12-11-2007, 10:10 AM
[No subject] - by Carl Travis - 12-11-2007, 12:54 PM
[No subject] - by Frank - 12-11-2007, 06:59 PM
[No subject] - by Frank - 12-12-2007, 09:17 AM
Philco 91 Tuning Condenser
There are currently 10046 online users. [Complete List]
» 1 Member(s) | 10045 Guest(s)
