Bakelite cap contents help
Question on bakelite block. I'm working on a Philco 118 and one of the blocks is labeled 3615AP but the schematic/parts list indicates it should be a 3615D which is a single .05. Two caps came out of it which makes me think that perhaps they moved another .05 tubular cap indicated on the schematic to the AP block. Can anyone tell me if indeed the 3615AP is a dual .05? It's not on Chucks list.
Thanks for your help.
Edit: Dummy me I should have looked at the service notes on the radio. Indeed, it was changed to the AP block to include another tubular .05.
Jerry
Bakelite cap contents help - by jerryhawthorne - 04-22-2013, 07:29 PM
RE: Backelite cap contents help - by klondike98 - 04-24-2013, 02:47 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3020 online users. [Complete List]
» 1 Member(s) | 3019 Guest(s)
