Self Osc in output on 41-296
Sorry, I meant 1 mc apart!
Is the LO on this band going to be heard 455 kcs below, or above the "tuned" freq.? The signal I hear close to 10 Mhz DOES have an LO below, but not above, if so I think I have the fundamental spotted and zeroed in on 10 Mhz now. The image above at about 900 kcs is a lot stronger than I would expect however. Nearly as strong as the fundamental. I can actually hear WWV in both spots too. I don't expect to get it within a needles width accurate. Actually 50 to 200 kcs would be fine with me. Maybe I have it pegged now since I was looking for the upper LO instead of looking below (10000 - 455 = 9545).
Brian
Self Osc in output on 41-296 - by w5ami - 04-17-2013, 04:06 PM
RE: Self Osc in output on 41-296 - by morzh - 04-17-2013, 06:19 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-17-2013, 08:14 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-17-2013, 08:21 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-17-2013, 09:21 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-17-2013, 10:03 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-18-2013, 06:38 AM
RE: Self Osc in output on 41-296 - by w5ami - 04-18-2013, 06:55 AM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-18-2013, 09:39 AM
RE: Self Osc in output on 41-296 - by w5ami - 04-18-2013, 09:47 AM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-18-2013, 04:20 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-21-2013, 03:08 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-21-2013, 03:26 PM
RE: Self Osc in output on 41-296 - by Raleigh - 04-22-2013, 04:28 PM
RE: Self Osc in output on 41-296 - by 7estatdef - 04-22-2013, 05:06 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-22-2013, 05:35 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-22-2013, 07:47 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-22-2013, 07:57 PM
RE: Self Osc in output on 41-296 - by BrendaAnnD - 04-22-2013, 08:36 PM
RE: Self Osc in output on 41-296 - by Mondial - 04-22-2013, 08:50 PM
RE: Self Osc in output on 41-296 - by 7estatdef - 04-22-2013, 09:19 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-22-2013, 10:21 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-23-2013, 01:42 AM
RE: Self Osc in output on 41-296 - by Raleigh - 04-23-2013, 02:57 PM
RE: Self Osc in output on 41-296 - by w5ami - 04-23-2013, 03:05 PM
RE: Self Osc in output on 41-296 - by Raleigh - 04-23-2013, 04:35 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6648 online users. [Complete List]
» 1 Member(s) | 6647 Guest(s)
